Body Buck Tags
Discussion in 'General Maverick/Comet' started by Craig Selvey, Oct 16, 2006.
  1. Craig Selvey
    Body Buck tags were only found on Canadian built cars and some American built cars.
    I thought I would start this thread and ask folks to post pictures of their body buck tags, and a description of the car it was found on. This way we can build one thread with all this info. Please only post if you have a picture and description. I will start:
    This body buck tag is off of a 1971 Ford Maverick 2-door. 302 V-8, C-4 AT, Factory AC, dark blue with a white full vinyl top, blue comfort weave interior with bench seat.
    Rotation Number: 0596
    28 DSO = 28 Louisville, KY
    Exterior color: Q = Medium Blue Metallic
    Trim: 5B = Medium blue - Deluxe Woven Vinyl Bench
    Axle: 6 = 3.00:1 Ratio
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I have the one off the 72 Grabber .... Red with white bucket interior I parted out .... I'll hunt for it in my Garage tomorrow ...
  3. Jamie Miles
    I beg to differ. My '74 Grabber was built at the Wayne, Michigan plant (4W93L V.I.N.) and has one.
    Here is the one off my '69.5. I also included a shot of the door tag that shows the 17G date versus the 15G on the buck tag. Car is Metallic Yellow, Black interior, bought new in the Atlanta district, 200/C4, 7.5 rear. The letters messed up by the screw hole on the left side appear to be UP and L below.
    I have to go to NC to get the ones off my brother's '73, and the '74 Grabber. I might try to go up there later this evening since I need to get some parts for my car.
  4. dmhines
    Cumming, GA
    Hmmm ... my 74 was also built in Wayne ... and it doesn't have one ... at least it didn't have one when I got it ... and I think the 72 tag I have is from a DearBorn car ...
  5. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    1970 Grabber, 170 c.i., 3 speed manual, black vinyl interior, Grabber Green exterior
  6. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    my car is candaian , is it that little tag on the core support??
  7. Dave B
    yes.
    Man I wish I could find mine, I put it somewhere so I wouldn't loose it, I have a box of them somewhere.....
  8. Jamie Miles
    Yes. When you open the hood, look down on the passenger side between the grille and core support. It will be attached to the core support.
    Attached below is the one on my Grabber. You can faintly make out the edges of it. If I remember right, it is attached with some sort of staple instead of screws. The info on it is formatted the same as on Canadian cars. I never knew it was there until after I wrecked the car and took the front end off.
      File size:
      43.5 KB
      303
  9. eddie1975
    Martinsburg, WV
    sold
    i could be wrong , but i think i remember seeing it on the passenger side towards the top , right above those slots in the support, i will have to check it out in the morning....
  10. dmhines
    Cumming, GA
    I just looked on my 74 and definitely don't have one ... and I would have remembered removing it when I did my Bumper swap if there was one.
    BTW ... The term BUCK isn't on WikiPedia so I may have to add the definition. A Body Buck was the the BUCK Welding process on the assembly line. All of the sheetmetal pieces of the body shell were clamped into a BUCK and then welded together. Following this process the vehicle was officially "born", then given a VIN number and moved onward into the assembly process. That is why on a Marti report you have a Buck Date and a Build Date. The Buck date is when the shell was assembled ... the Build date is when the finished vehicle rolled off the assembly line. Generally the dates are not the same .... The Buck Tag was probably used in addition to the Build Sheet to insure the car was assembled with all the proper options ...
    As far as location ... The 72 I parted out was higher up on the passenger side. The 1984 Mustang I owned also had one in the same place upper driver side radiator support.
  11. Jamie Miles
    I think adding it to Wikipedia would be a great idea. And yea, My '69.5 and '73 2 door both have them higher up on the passenger side, in plain view when you open the hood. The one on the Grabber was totally hidden by the front bumper and filler panel and all that.
    The date on my '69.5 is July 15, 1969, and the date on the door tag is July 17th, so that would also support what you say.
  12. Earl Branham
    Lugoff, SC
    Mine was on the car, but was destroyed. It fell apart when I tried to clean it up. Made in Canada (Windsor).
  13. Acornridgeman
    Wisconsin
    My car is a Dearborn car.
    200-I6, C4, color 5L = tan exterior and BF = ginger brown interior, bench seat front
    Anyone know what the CHR and the 504 would mean?
  14. Craig Selvey
    504 is probably the rotation number. All cars were numbered 1 thru 999 on the assembly line as they were "routed" through the assembly plant. Once the got to 999....they started over again at 001. On the body buck tag I posted the rotation number was in the upper left corner.
  15. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    Here's mine from the Sprint. DSO code B4 = midwestern Canada. I'm sure someone with a keen eye will notice the pic is actually of the back side of the tag...couldn't get a legible pic from the front so I snapped it from the back and flipped it left to right.
