Body work/ rust repair
Discussion in 'Cosmetic' started by Acedmav75, Mar 31, 2015.
  1. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Hey guys, I wanted to know if some of you have run into this issue and if so any recommendations on fixing it. There seems to be a lot of rust holes on the bottom area on the rear just behind the rear bumper. Seems on some spots where the rust holes are the previous owner put a mound of bondo on it too. I began kind of cleaning the areas of rust but not sure how i should go about fixing it.
  2. 71gold
    replace the tail panel...:thumbs2:
  3. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    know where i can buy one?
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Put a post in the parts wanted section, I imagine you will get a response there.
  5. Craig Selvey
    I see no need to replace the entire tail panel. If that is the only rust on the panel, just have a body shop WELD in new metal in that area. Where it is located....pretty easy area to hide.
  6. 71gold
    what does this mean...:huh:
  7. rthomas771
    Where it is located will be pretty easy to hide...or...Pretty easy to hide where it is located (??)
    Craig Selvey likes this.
  8. Craig Selvey
    It means that once the repair is made, and the car is painted and reassembled, the area of the repair will be virtually unseen by the naked eye. The same can be said for floorboard repairs, for example. In contrast, a rust repair made on the top of a fender, or on the rear quarter panels around the wheel arch, can possibly be seen once the repair is made because those are more visible areas of the car.
    In my opinion, the amount of "hours" and "labor" that would be use to repair the area the original poster is describing would be quite a bit more to replace the entire tail panel than just to fix the area described.
  9. 71gold
    from the looks of the overspray, someone has already "hide" it once...:huh:
  10. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    One way would be to buy a cheap mig welder get some replacement metal cut it out and weld the metal in then finish the area you are working on like was said it is in an area that is easy to hide plus you have learned a new skill Welding patch panels its not the easy way but you will have gained another skill needed to work on old cars I have turned into a fair welder working on patch panels on my Maverick and it was a skill I didn't have before when it is done I will have saved a lot of money.
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Hit the area with a sandblaster. It will eat all of the weak areas and give you a better idea of exactly how much "good metal" you have left. In the end, your common sense will prevail.
    I am in general agreement with Craig. Unless the area is extremely eaten out by corrosion, I would repair it.
    Paul Masson, mojo and Craig Selvey like this.
  12. mojo
    I also think that panel maybe repairable. I have seen much worse repaired.
  13. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    There's probably a lot more rust hidden than you would like to find. Luckily that's an easy spot to fix, but unfortunately I can see you digging more and more and before you know it your car is in 100 pieces. Good luck and keep us posted.
    71gold likes this.
  14. mav1970
    That is what I found with most of the small rust areas of my own car - got to get in there and get it all
