Bog warner T5 swap
Discussion in 'Transmissions' started by Rogue302, Aug 5, 2017.
  1. Rogue302
    Rogue302 Member
    Massachusetts
    Hey guys,
    I'm looking to start setting up my maverick for road racing. I'm looking to swap a T5 into my currently automatic c4 car (floor shift). I came across this Bog Warner "World class" T5 with the bell housing, clutch and brake assembly and clutch cable. Is this pretty much everything is need besides a flywheel/flexplate? I know I can use my current driveshaft. And I'll have to modify or find a new trans crossmember. Also, does this seem like a good deal? $600 for everything Screenshot_20170805-154141.png
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Try to locate some pedals that are FOR a Maverick or Comet .. You'll be glad you did ! Just my opinion.
    Cometized
    (Chip)
    Rogue302 likes this.
  3. Krazy Comet
    Is it possible to use a cable with the original "linkage" type pedals?? I understand with enough fabrication anything is possible, but seems to me would be a lot changes necessary..
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I would go hydraulic and forget the cable. You can use an external slave cylinder or a hydraulic throw out bearing. I recommend the former if for no other reason that it is easier to repair in case of leaks. Maverick/Comet pedals are easier to work with, but they are starting to get pretty pricey.
