Im gonna have to change my rear, what rears bolt in our cars if any, mines a 70 if it matters and im going 5 lug
Find a later model Maverick 5 lug rear end. That would be easiest. You can run a rear end out of a 67-68 Mustang too. It's a little wider but would work out better if you were to add wheels that have to offset of newer Mustang wheels.
Remember to look under every Granada or Monarch you find because Ford was never consistent with what combo they would put a 9 inch in - V8 - 6 cyl - 4 door - 2 door - could be under anything - also mine came stock with disc brakes - now Lincoln Versailles, which is also based on the Granada platform, were all 9 inch rears and all were disc brakes
Exactly, I should have been clearer - the 9 inch rears that came under the Granada/Monarch could be either drum or disc brakes - all of the 9 inch rears under the Lincoln Versailles were disc
