Brackets, brackets, brackets.
Discussion in 'Technical' started by Maverick_Matt72, Mar 2, 2007.
  1. Maverick_Matt72
    Maverick_Matt72 Member
    Deep In The Heart Of, Texas
    '69.5 Maverick
    Got a Granada 8" rear end. Need to swap it in. Has brackets for leaf springs only... doesn't have the little 45 degree angle "dog ear" kind of tabs coming off those brackets, used for the shocks, as does the rear end in the Maverick. What's the best way to go on fixing this? I suppose I could get some hellacious thick flat-iron and weld some onto the brackets of the Granada rear end? It's not really feasible to cut the brackets off the old rear end and use them on the granada rear end is it? That would ruin both the brackets and the rear end in the process, I'm pretty sure.
    Help please!
  2. PaulS
    Put a plate between the spring and mount with an ear on it for the shock. It will raise the rear a bit but only as much as the thickness of your plate.
  3. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    Mustangs Plus has these, I used something like this from Total Control, which worked with the 3" axle tubes in my car.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The shock mounts are on the spring plates, not the rear end... :huh:
    All you need to do is mount the Granada rear with the Maverick hardware.
    That would include the plate with the shock mounts...
