Brake hose for 1970 with 4 lug?
Discussion in 'Technical' started by Xaan, Aug 24, 2012.
  1. Xaan
    Xaan Newbie
    Germany
    70`3,3
    Hello,
    I need for my 1970 Mav with 4 lug new front brake hose. At rock auto I can not find it. Experience that fit the 1970 Mustang with 4 lug?
    Nils
  2. Acornridgeman
    Wisconsin
    The 1970 Maverick hose is a 1 year only design - no other car used the same ends that the Maverick did. New parts are no longer made, but they do pop up from time to time on ebay. Used hoses are out there - you might want to try a wanted ad here in the forum classifieds.
    If you have your old hoses. You can take them to a hydraulic hose repair shop and they can take your old ends and put them onto new hoses.
    Hope this helps ........ :)
  3. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    You can also, change out the brake cylinder for a later one and replace the hose. I've done this before and it works.
  4. Acornridgeman
    Wisconsin
    That is a cool solution - do you by chance have part numbers from the swap? Was it just a matter of putting in like 1971 wheel cylinders and hoses?
    (y)
  5. Xaan
    Xaan Newbie
    Germany
    70`3,3
    I've found in the forum looking for a post in which is written from the 1970 Mustang 6 cyl. the hose is just a little longer, but fits. Can anyone confirm this?
  6. mike75mav
    mike75mav Member
    Bremerton, WA
    Just find brake cylinders for a 71-73 and get the hoses. I think any year would do but, not sure.
  7. tody
    tody Member
    cologne, germany
    if the hoses are rotten, there's a good chance the brake cylinders are, too.
    i'd change them both. also check the brake shoes!
  8. rthomas771
    I'd replace the wheel cylinders anyway. Or at least look inside them.
  9. simple man
    simple man Member
    Bunnell,Florida
    EEK! I hope that wasn't from a car that was being used! :eek:
  10. rthomas771
    It would had if the PO knew that you set the point's gap to .025 and not 0.25" that he set them at. But I think the Mustang gas tank would had fell out on the ground before he got to the stop sign. You know...some people don't need to be working on cars
  11. Xaan
    Xaan Newbie
    Germany
    70`3,3
    So when I wheel cylinder from 73 ' mount, also its fit brake hoses from 73?
  12. Xaan
    Xaan Newbie
    Germany
    70`3,3
    Nobody knows that?
  13. tody
    tody Member
    cologne, germany
    should fit fine!
  14. Xaan
    Xaan Newbie
    Germany
    70`3,3
    I have now ordered from RockAuto 2 brake hoses and 2 wheel cylinder from model 1973. I have now discovered that the new brake hoses fitted well to the old wheel cylinder. Perhaps these have been replaced already times ....
    Regards Nils
  15. 1970TexMav
    1970TexMav Member
    Texas
    I have the same problem with my 1970 with factory drums. I ordered the 1979 small 6 cylinder front brake lines and the 73 front wheel cylinders from Rock Auto. The problem is that the bent metal fitting that attaches to the frame and the curved banjo fitting that attaches to the back of the wheel cylinders is not on the 73 hose and therefore it does not reach the back of the wheel cylinder. Checking to see if someone has found a solution to the 1970 front brake line replacement.
    Thanks
