Brake lights out, where is switch
Discussion in 'General Maverick/Comet' started by marty robbins, Oct 5, 2003.
  1. marty robbins
    marty robbins Member
    Olympia, Washington
    1975 Maverick Grabber
    Can anyone tell me where to find the brake light switch for a 75 maverick, I did not see any wires going to the master cylinder so it is probably under the dash, my Chiltons does not have it, or so I can't find it. I did check the bulbs they are fine, but the other day when I was putting it in the garage the brake lights stayed on I pumped the brake peddle and they went out, the other day when stopping my son behind me said they were not working and he was right, anyhelp much appreciated. Marty
  2. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    its under the dash on the rod that comes out the back of the master cylinder good luck ;)
  3. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    yep right where the rod connects to the brake pedal.
  4. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    same problem with my 77 granada about a year ago, the switch was the culprit good luck
  5. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    One in the column too....
    When my brake lights quit, I changed the one under the dash, but wound up having to change the one in side the steering comumn too. That lil' booger was expensive. Hopefully your's will be under the dash, and it is not an expensive part. Don't remember what I paid, but it was cheap. Good Luck.... Preston
