brake lights
Discussion in 'Technical' started by tommyboy, Jul 11, 2012.
  1. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    Hey guys was wondering if anyone knew what would cause my brake lights to quit working put in new bulbs check fuses and they still dont work any ideas on it would be great
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Check the brake light switch on the brake pedal. Hope its not the turn signal switch. :cry: I haven't been able to find one.
  3. tommyboy
    tommyboy 77 mav
    1977 maverick
    Thanks i will check it hope i can still get those switches
  4. vvr210
    vvr210 Member
    Vista,CA
    Is this switch located right under tha brake pedal?I have the same issue
  5. Jsarnold
    '72 Sprint
    Yes. Look under the dash and you'll see it.
  6. rthomas771
    Not really "under" the brake pedal but in front. :D
  7. vvr210
    vvr210 Member
    Vista,CA
    Is that what its supposed to look like if its functioning correctly?
  8. 71gold
    yes....and it will go on upside down and not work...:yup:
  9. tommyboy
    tommyboy 77 mav
    1977 maverick
    Thanks for the help guys went out and unplugged the switch cleaned the connectors and now i have brake lights:) love this site
  10. Bob Wiken
    Fayetteville, Arkansas
    I love it when a plan comes together. I have had gotten the same results from many members here. It's well worth the cost of membership. Join up.
  11. vvr210
    vvr210 Member
    Vista,CA
    Wow..I went and did the same thing..CLeaned the connector..Popped it back in and there we go..We have brake lights now!!!Thanks a lot guys..Now I need to figure out why my back up lights dont work..Any thoughts?
  12. vvr210
    vvr210 Member
    Vista,CA
    After I got my brake lights working I found out that I have to step hard on my brakes all the way for the light to go on..Does anyone know how I can fix this?
  13. maverick@heart
    maverick@heart Member
    Hendersonville TN
    1975 American Maverick, 1976 Mexican Maverick, 1973 Maverick
    I had the same issue. I changed the switch and the issue was corrected..
  14. vvr210
    vvr210 Member
    Vista,CA
    Is the switch th eone mentioned in the picture above?I hought I would have to bleed my breaks or something
  15. vvr210
    vvr210 Member
    Vista,CA
    So even if the light does come on would I have to replace it?
