Brake line fittings
Discussion in 'Technical' started by et5230, Feb 26, 2008.
  1. et5230
    et5230 Member
    Iowa
    71 Grabber, 82 Mercury Zephyr 502 ci
    Maybe everyone here already knows this, but last week when I was replacing brake lines on my 71 I found that Carquest has 8" pieces of 3/16 line with a 3/16 tube nut on one end and a 1/4 or 5/16 tube nut on the other. When I was building new front lines, before flaring the ends I put new 1/4 tube nuts on the ends that joins with the brake hose. Would also work from the master cylinder to proportioning valve or any place where you need a larger nut for 3/16 line. 3/16-1/4 part number is 318A, 3/16-5/16 is 328A. They also have several other configurations. I got them just for the tube nuts, the old ones were permanently fused to the lines, and had been vise-gripped off in the past. My brake lines are now new end to end. Hope this might help someone out.
  2. PaulS
    Thanks for the heads up! I am sure it will help someone here.
