Brake Switch Substitutes
Discussion in 'Parts Interchange' started by RUBEN VARGAS, Nov 18, 2005.
  1. RUBEN VARGAS
    RUBEN VARGAS Member
    Houston, Texas
    1974 Mercury Comet
    11/18/05
    I've been running around with no rear brake stop lights. Local autozone is out of stop brake light switches. Can I use a substitute from another car?:confused:
    rv
  2. Jamie Miles
    I highly doubt it. I have never seen another car with a brake light switch even similar to a Maverick switch.
  3. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Try NAPPA or another parts store. Someone has them.
  4. Mavaholic
    I'll bet the 69-73 Mustang is the same.
  5. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    ruben take it down to johns mustang, an see if it matches up with a mustang. if not i think i have a extra.
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
    the one in our 68 cougar was pretty similar and could have been modded to fit. only in a pinch though, you will want the right one asap. the cougar had power disc brakes(stock) and i had to take three back to get one that worked correctly. apparently the non power one looks exactly the same but takes more force to activate.:huh: so even if you find a switch that looks correct and seems correct, if it isnt for the right brake setup, you may just about have to slam on the brakes before the switch activates.:mad: you should see the little plastic piece of !@#$ they put in my big F250 change that one almost yearly:mad:.
  7. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Instead of running around lightless (clueless to others), I have wired in a simple toggle switch to keep from getting rear ended and to warn other drivers of my intentions. Please keep in mind that this was only a temporary fix. it was latter fixed right with the right part.
  8. Jamie Miles
    Thats exactly what I did for a couple of days when I couldn't figgure out how to get mine back on. Just bought a $2 horn buttom from Wall Mart and wired it up and set it on the seat. Every time I pushed the brakes, I pushed the button. :)
    One night one of my friends was following me in his truck and there was a SUV between us. He was behind the SUV. I kept pushing the button and every time I did he said the SUV would tap his brakes also even though I wasn't actually hitting my brakes. That was pretty funny. :)
  9. fan2488
    fan2488 Member
    spring,TX
    i found my extra one, its yous if you still need it
  10. sierra grabber
    northern nevada
    Jamie,
    :lolup::rofl2: wish id done that when i lived in the bay area. back off some of those 70 MPH bumper riders real quick
  11. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    the standard part # with power brakes is sls92 with out power brakes is sls70
