Brake upgrade
Discussion in 'Technical' started by owlshado7, Feb 17, 2003.
  1. owlshado7
    owlshado7 New Member
    Albuquerque
    '70 Mav I6 250:'77 parts car--- looking...
    Does aynbody know if I can put the front disk brakes from my '77 4-door parts car on the front of my '70 Mav?
  2. owlshado7
    Albuquerque
    Sorry-- "anybody." And I mean, is it a direct swap, or will I have problems with the steering and suspension?
  3. Mavaholic
    The very early Mavericks had a different A arm but I cant remember if it was the top, bottom, or both. Either way you could use the A arms off the 77 and everything will bolt up if there is a difference.
  4. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    dennis- i hear the tern "early" a lot. any idea where in the production numbers "early" stops? as you may know, i also have a 70 and am (after this snow melts) going to do the brake swap from my 75 parts car. or does "early" end when they went to key on the column? thanks.
  5. Mavaholic
    I'm not the expert but I believe the the change was with the keyed column lock.
