Brakes ???
Discussion in 'Technical' started by mavgrab302, Jul 21, 2014.
  1. mavgrab302
    I'm disappointed in my brakes and need to do something about it. (disc front , drum rear) I have said before my pedal seemed to be to low when I applied the brakes. Now after it sat for a while (engine/trans swap) they are worse than ever. Two things I have noticed is 1, I think I'm only getting front brakes. 2, For some reason my master is full to the top, it wasn't that way before. I always kept it about a 1/4 inch below the cap. I want to upgrade to a better master IE: 89/90 Ranger and rebuild my rear drums with new parts... What else should I do ?
  2. 71gold
    are these the brakes that came on the car?
  3. mavgrab302
    I have 76 mav front disc and stock rear drum.. I installed the front disc brakes 3 years ago with all new parts, I replaced my front pads last year because old ones rattled... the rear had new hardware shoes and wheel cylinders 3 years ago... all new rubber lines front and rear...
  4. mojo
    mojo "Everett"- Senior Citizen
    Are we talking new mc on the car w/ the rest of parts u replaced?
  5. mavgrab302
    Everything was replaced when I built the car 3 years ago... new master too...
  6. mojo
    Do u have the shoes adjusted close to the drums? All the parts springs, etc in proper location? I wud pull drums and make sure all parts are in proper location; if u haven't already. Other than that, the mc may be defective or wrong mc.
  7. Rasit
    Rasit Member
    SE Pennsylvania
    Is it a two chamber master cylinder like this?
    The disks need more fluid and work off of the larger chamber. Did you change the proportioning valve or leave it stock (drum/drum)?
  8. Krazy Comet
    Excessive pedal travel in a disc/drum system is almost always related to the rear brakes... Can be as you suspect, not functioning or badly out of adjustment... Since fluid level has risen, I'd suspect the check valve in the MC has failed which has allowed the brake shoes to retract back into the wheel cylinder, rendering them useless... The one fly in this theory, they should pump up with two or three jabs on the pedal... If one of the cups inside the MC has failed that could cause your issue, as pedal would never pump up or likely sink quickly again if it did...
  9. mavgrab302
    I checked and adjusted them this past weekend..
  10. mavgrab302
    Yes the master is for a 76 mav/comet.. Stock drum/drum valve is still being used...
  11. mavgrab302
    I can pump them all day long hight never changes. I looked at the wheel cylinders while i had the rear drums off,no leaks. I'm going to replace the rear drums with new,just because that is the only thing I didn't do last time. I think it's either a blocked brake line or the master cylinder...
  12. mavgrab302
    I ordered a early 1990 Ranger master cylinder to try... I heard they work pretty good is our cars...
  13. m in sc
    m in sc Member
    rock hill sc
    its probably just the master cyl itself. how far off the floor is the pedal?
  14. mavgrab302
    When I apply the brakes the pedal is about 3" off the floor. the pedal acts the same as when the brakes worked well, I don't think the rear brakes are being activated anymore.
  15. mojo
    I think changing the mc will solve the problem. I don't think a drum/drum on a disk/drum setup is the way to go. If u had very weak expulsion of fluid when bleeding the rear wheels wud indicate a possible line issue, seeing as everything else is new.
    Also, rust fluid might indicate rusty/blocked lines.
