Brasilian Maverick pictures
Discussion in 'General Maverick/Comet' started by MavekoV8, Sep 5, 2002.
  1. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    1974 Maverick GT & 1973 Mustang Mach1 & 1985 VFR 1000R
    Stefan
    Well, i realy try to take a shot of the full car, but i can´t.
    My garage is too dark and if i step back to put it all on the "QUADRO", the shot was a complete nothing, so i take shots of parts of it
    Here the one of the rear
  2. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    continuing
    The car is missing the letters F, O and D of the FORD logo on the back, but i have all the letters and will assemble it after a bodywork repaint.
    Here is the backpart of the car
  3. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    and...
    Here is the "CAUSE" of the bodywork that i told you...
  4. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    and...
    This one from the front part of the car...
  5. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    and...
    This ones, at last that i know, reflects the main difference between Brasilian and American Mavericks...
  6. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    Finnaly
    The right part of the panel
    Thats it for now. When i can take the car of the garage, i will take more well taken pictures of it
    MArco
  7. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Re: rear end and other items
    Guys, and Marco-
    I bet that is some type of early version of the current 8.8 housing with the check plate. If he is correct in stating that most cars and light trucks use the same rear end, I doubt it is a 6 3/4 or 7 inch rear. I guess it is possible that it is a replacement rear end. But having 5 lugs I would guess it is not a 6 3/4 behind a V-8.
    I didn't see the question answered re: transmission, in one picture there seemed to be a console/consolette?
    Also, I like the KM speedo and the factory tach, looks like the speedo assembly. There must be a ton of room under the dash without the lower sections as package trays and later glove compartments like our US built cars.
    Neat pics, good luck with the problem Marco.
    Seth
    seth@realtor.com
  8. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Re: rear ends
    I copied this from one of the other websites with lots more info.
    This is form the , ...pete...edu site, sorry I can't remember to give credit.
    Ford Differentials
    The following information has been copied from the Ford 1978 Car Shop Manual Volume 1, Chassis.
    Integral Carrier Axle-Conventional
    Applies to Mustang II/Pinto/Bobcat
    ID tag......Ratio...... Ring Gear.... Differential
    ........................Diameter (in).... type
    WGB-K1..... 3.18:1..........6.75......... C2
    WGB-U1..... 3.18:1..........6.75......... C2
    WGF-AA..... 3.18:1..........6.75......... C2
    WGF-AJ..... 2.73:1..........6.75......... C2
    Integral Carrier Axle-Ford-(WER)
    Applies to Ford/Mercury, Granada/Monarch
    WER-AA..... 2.47:1..........8.7.......... C2
    WER-AB..... 2.47:1..........8.7.......... C2
    WER-AC..... 2.47:1..........8.7.......... C2
    Integral Carrier Axle-Ford-(WGX)
    Applies To Fairmont/Zephyr
    WGX-A...... 2.73:1..........7.5.......... C2
    WGX-B...... 3.08:1..........7.5.......... C2
    WGX-C...... 2.47:1..........7.5.......... C2
    Removable Carrier Axle-Ford
    Driving axle identification - Lincoln Continental and Continental Mark V
    WGB-V...... 2.75:1..........9............ C2
    WGB-W...... 3.00:1..........9............ C2
    WGB-AB..... 2.50:1..........9............ C2
    WGB-AD..... 2.75:1..........9............ C2
    WGC-A...... 2.75:1..........9............ C2
    WGC-K...... 2.50:1..........9............ C2
    WGC-N...... 2.75:1..........9............ C2
    WFV-T...... 2.75:1..........9............ T4
    WFY-A...... 2.75:1..........9............ T4
    WFY-K...... 3.00:1..........9............ T4
    Driving axle identification - Ford and Mercury
    WDC-DW..... 2.75:1..........9............ C2
    WDC-EB..... 2.75:1..........9............ C2
    WDC-EE..... 3.00:1..........9............ C2
    WDC-EH..... 2.75:1..........9............ C2
    WDC-EK..... 3.00:1..........9............ C2
    WDC-EL..... 2.50:1..........9............ C2
    WDC-EM..... 2.50:1..........9............ C2
    WFG-AL..... 3.00:1..........9............ T4
    WFG-AA..... 2.75:1..........9............ T4
    WFG-BJ..... 2.75:1..........9............ T4
    Driving axle identification - LTD II, Cougar, and Thunderbird
    WEB-BF..... 2.50:1..........9............ C2
    WEB-BK..... 3.00:1..........9............ C2
    WEB-BM..... 2.75:1..........9............ C2
    WFA-AA..... 3.00:1..........9............ T4
    WFA-AH..... 3.00:1..........9............ T4
    WFA-AL..... 2.75:1..........9............ T4
    Driving axle identification - Mustang II, Pinto, Bobcat, Granada, Monarch and Versailles
    WDW-AB..... 2.79:1..........8............ C2
    WDW-Z...... 3.00:1..........8............ C2
    WDX-E...... 2.75:9..........9............ C2
    WDY-AA..... 3.00:1..........8............ C2
    WDY-HH..... 3.40:1..........8............ C2
    WDY-S...... 3.40:1..........8............ C2
    WFB-G...... 2.50:1..........9............ T4
    WFB-K...... 2.50:1..........9............ T4
    Traction-Lok Limited Slip Differential-Ford
    Granada,Monarch,Versailles
    LTD II, Cougar, Thunderbird
    Lincoln Continental, Continental Mark V
    Ford, Mercury
    Type: C2,C4-Conventional 2-Pinion, 4-Pinion
    T2,T4-Traction-Lok 2-Pinion, 4-Pinion
    Notes:
    For Mavericks and Comets the Granada/Monarch/Versailles tables are the ones to use as these cars are based on a lengthened Maverick chassis.
    Axle codes from data plates
    These codes are assembled for 70s Ford using the '78 shop manual, '75 light maintenance manual, and The Mustang Recognition guide. codes are fairly stable from 1969 to 1978, notes are made where needed. Please double check any codes not in the years 1969-1973, 1975, and 1978 since I can only assume the codes remained the same in the years my sources do not cover.
    Conventional......Lock......Ratio
    1.............J.........2.50
    2.............K.........2.75
    3.............L.........2.79
    4.............M.........3.18 ('78), 2.80 ('69-'72)
    5.............N.........3.07 ('75-'78) 2.83 ('69-'70)
    6.............O.........3.00
    7.............P.........3.40 ('73-'78) 3.10 ('69-'70)
    8.............Q.........2.73 ('78) 3.20 ('69-'70) 3.18 ('72)
    9.............R.........3.25
    A.............S.........3.50
    B.............T.........2.47 ('78) 3.07 ('69-'72)
    C.............U.........3.55 ('72) 3.08 ('69-'70)
    D.............V.........3.91
    E.............W.........4.30
    F.............X.........2.33 ('70)
    G.............X.........3.55 ('73-'78)
    H.......................3.78 ('72)
    Y.......................3.08 ('78) 4.11 lock ('72)
    Disclaimer: Not responsible for any errors, etc.
    Return to Maverick / Comet home page.
    Maybe this helps.
  9. Stefan
    Montreal, QC
    Thanks for taking the pics. Looks like you have a nice project on the way!
  10. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    Info
    Thanks Littleredtoy
    I thank you very much about the info...
    I have collected as much as info that i can about ford differentials, but the Ford differential on my maverick stays a mistery...
    By the way, i´m writting to ford Brasil to ask if they can help and if they can´t, i´ll take it off the car and measure it. This looks like the right thing to do now, as soon i buy another batery a make the car come back to life!!!! ehehehehehe :)
    Stefan, thanks you too, and if you like to see another angle of a Brasilian Maverick, please tell me as soon as you can, cause the digital camera is from a friend of mine and i´ll take it back to him on monday!
    Marco
  11. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    Thats a nice brazilian mav you got on your hands!
    Maybe some pics of the interior and the engine.
  12. 76MavStallion
    76MavStallion Member
    La Crosse, WI
    1976 Maverick Stallion, 302 3spd.
    Any idea where we can get a tach like that in the states? Maybe get one shipped up from Brazil?
    Jon,
    jonhohlf@yahoo.com
  13. MavekoV8
    MavekoV8 Member
    Sao Paulo - Brasil
    Tach
    Will,
    My friend extended mys stay with the camera ´till next monday, but since i don´t have taken the batteries charges from him, i´ll have to wait the weekend to recharge them , to finnaly take the shots you ask.
    Jon,
    As i have explained to Seth, this tachs are a very hard to find even here in my city (São Paulo), where were sold the great part of the GTs in Brasil. However, as i have also explained him, if you give me the time to search, it can be possible. Please, e-mail me with your data and we could talk in private
    Best Regards
    Marco
