Bucket seat tracks
Discussion in 'Cosmetic' started by Ronald Hopkins, Jan 7, 2015.
  1. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    Can some one post pictures showing the seat tracks installed in their car. My seats lean in at the top. I think when I had it upholstered the seat backs were installed on the wrong bases. Would this cause them to lean in at the top.
  2. Acornridgeman
    Wisconsin
    Are the spacers there for the inside track? There is a bell shaped one and a long u shaped pedestal that is for the rear. Other than the backside release to tilt the seat forward, the backs and seat bases are the same dimensions.
    Here is a pic of the tracks with spacers.
    Mel Moeller likes this.
  3. Ronald Hopkins
    1972 Comet GT
    mine does not look like those but they are the orginal ones for my 72 comet. Mine has a bell shaped one on the outside rear and an long one on the inside rear. Thinking they may be wrong. The seat backs have the latches on correctly for the seat tilt. Thinking maybe when they were uphlostered they may have the seat backs on the wrong bottoms.
  4. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Like this?
  5. Acornridgeman
    Wisconsin
    I have my buckets out of the '72 right now, but I'm pretty sure the bell is for the front of the inside track. The outside track has no spacers. Having the bell on the outside rear would definitely make the seats tip inward.
    Seat bottoms are not side specific, at least with the factory high backs. I think it is that spacer bell.
  6. Ronald Hopkins
    1972 Comet GT
    Thanks for the pictures of the seat tracks but they are not helping I need pictures of them installed in the car. Showing which ones go to the outside rear and inside rear.
  7. Acornridgeman
    Wisconsin
    Those look like the longer ones that came on the LDO tracks. They work with any seat too.
  8. Acornridgeman
    Wisconsin
    Ron, look at the picture in post #2 - from left to right
    Passenger outside
    Drivers outside
    Passenger inside
    Drivers inside
    See how the spacers are all on the inside tracks? Bell in the front - u shaped bracket in the rear.
  9. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    Maybe this will help! The shorter studs go to the outer tracks and the longer studs go to the inner tracks. The bell goes to the front inner and the larger spacer goes on the inner to the rear. If you have any spacers to the outside track nearest to the doors it should tilt them incorrectly.
  10. Mel Moeller
    Twin Falls Idaho
    Ah-ha. A Very informative thread! :thumbs2::thumbs2:
  11. Craig Selvey
    These guys have it correct.
  12. Ronald Hopkins
    1972 Comet GT
    Thanks guys the bell spacers were on the outside rear. Changed them now they look a lot better.
    Paul Masson and Craig Selvey like this.
