bushing question
Discussion in 'Technical' started by comet 75, Mar 5, 2004.
  1. comet 75
    comet 75 comet 75 swap 302
    Quebec
    mercury comet 1975 302
    Hi guys, when I go on the road there's a knoc knoc in my trunk first i think that it the spare but no and now I thing that is the leafspring bushing what are thinking about it????
    And what hardware do I need to make a real good job cause when I change something it doesn't a mater to change everything around and I want it clean
    Thanks
    David
  2. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    When do you hear the noise exactly. When you take off of is it when you hint a bump in the road. If it is when you are taking off you might have a U joint going out and that is something you don't want to go out when you are on the road. And if it is when you hit a bump or pot hole something like that you might have a rear shock bad. These are just two things to think about.
  3. comet 75
    Quebec
    yeah it's when I hint a bump but for the cost of the bushing i thing that it's not a luxury but when you are talking about my shock was finish you mean my leaf spring cause there is no rear shock and the sound come from the rear of the car
  4. squeal1
    Evansville, IN
    Well man if you don't have shocks on the back then that is your problem. All cars that I know of have shocks on the back. You should have two of them. Or maybe I am just not understanding what you are saying, but you need shocks on the back of your car.
  5. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    Not all mavs came with a rear shocks dont quote me on this but i think 71 was when they first got them. Leafs yes all cars have them but the staggered shocks no.
  6. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    All mavericks have rear leaf springs and shocks...maybe not staggered shocks but they do have shocks....... Your ride and safety should improve greatly if you get them on.
  7. Mavaholic
    Your not in the mafia, are you?
  8. comet 75
    Quebec
    ok guys may be i was wrong but my car is so far away to verify so I'll be back later on this
    thanks
  9. comet 75
    Quebec
    ok guys may be i don't pass enough time under my car cause there was shock at rear so as punishment I'll pass the week end under my car cause I just took my car out for summer and it's time to work
    thanks guy and sorry for my ignorance
