anyone have pictures of the shifter rod and the trans kickdown rod connected to the c4. Also how do you get the shifter off of the transmission.
are you wanting to remove the...shift lever? if so, hold the lever and remove the nut. don't let the lever go to the end of it's stroke and bottom out against the case....it will break the paul off on the inside of the transmission. Frank...
