C4 bell Casting numbers
Discussion in 'Parts Interchange' started by Mavit, Feb 9, 2012.
  1. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    Can some one tell me the Casting Number on the bell housing for the 157 tooth flywheel on the c4 Maverick tranny. Need the right bell for a Ranger V8 project ! Thanks
  2. rthomas771
    C5OZ- 7976-A or D7BZ- 7976-A or D3BZ- 7976-A are the part numbers that came on the 73-77 Mavericks.
  3. jmgford
    jmgford Member
    Iowa
    Mavit, Is there any reason you need a bellhousing from a Maverick?
    I built a V8 Ranger using the engine & transmission from a '73 Grabber. There are other 157 tooth C4 bellhousings that were used in other cars that should work as well.
    I believe there are two basic V8 C4 bellhousing sizes, 157 tooth flywheel (case-fill) & 164 tooth (pan-fill). *There was a small oddball 143 tooth for the Mustang II
    '64 & '65 pieces are for the early 5-bolt blocks, but any other 157 tooth case-fill C4 bellhousing should fit. There are some that have additional bosses for mounting a shift cable and such, but are the same physical size.
  4. rthomas771
    '65 was the first year for the 6-bolt block. The '63 5-bolt blocks had a 160 tooth. Some, but not all, 64's got the 157 tooth.
