C4 lines and fittings
Discussion in 'Transmissions' started by jnew42, Oct 8, 2009.
  1. jnew42
    jnew42 Member
    Sacramento, CA
    65 Comet caliente 4 door
    I have a 65 comet and i'm putting the c4 back into it but the cooler lines are broken. They were broken and the trans was out when I bought the car, the guy also told me I needed to get some brass fittings for the cooler lines but i can't find the part or mention of it anywhere. Was the guy lying to me and what do i need to make the cooler lines?
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    if you are talking about the two fittings on the side of the trans, they are a royal PITA to find. i ended up using summit AN fittings and steel braided line to come from the trans out to the regular steel line instead as none of the parts stores even seemed to know what i was talking about :(
  3. jnew42
    jnew42 Member
    Sacramento, CA
    What size fittings did you use? i think that might be the route i have to go.
  4. sierra grabber
    northern nevada
    i cant remember off hand but when i get home i will see if i can dig up the reciept. i keep thinking 1/4??? but i also bought one for the fuel pump so.......also you could check with a trans shop, one near me said they could match it if i brought the fitting or car. the fitting i had tossed due to it being broke...
  5. PaulS
    The transmission sooler line fittings are 1/8" Straight pipe thread with o-ring seal. You can find them at most transmission supply / parts stores. The lines are 5/16" steel lines like the fuel lines you can buy in parts stores in various lengths. You can bend them yourself with a little care and forethought.
    You can also use 1/8" taper pipe fittings with a 5/16" inverted flare to go into the transmission. You will have to use a good sealer like teflon tape or loc-tite 518 on the threads if you use the taper pipe fittings. The fittings should be 90 elbows - the rear fitting faces forward and the front fitting faces rearward.
  6. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    i just had to replace mine on my c-4 and i found them at napa and they can also make trans line but its a little pricey also they told me to use 1/4 inch line for the trans.they are called transmission case fittings.
  7. scooper77515
    I used the tapered pipe threaded fittings like PaulS said. Working fine so far...
