C4 must be revved before abruptly moving forward in drive
Discussion in 'Technical' started by roblaw, Jan 28, 2019.
  1. roblaw
    roblaw Member
    !973 Maverick 302
    1973 Maverick Grabber, 302 auto. When i put in drive it will not move unless revved up a bit. Then it abruptly engages, even barks the tires. Reverse is the same but less rev needed. Also, the whole car shudders when revved in neutral. The engine will also drag to a stall after driving at speed and coming to a stop. I bought car this way. Because of shudder and increased stall speed, i'm thinking torque converter . Any thoughts?
  2. x72COMETx
    x72COMETx Member
    Vallejo CA
    Low on trans fluid?
    baddad457 likes this.
  3. Krazy Comet
    Loose valve body bolts can cause the same.
  4. roblaw
    roblaw Member
    !973 Maverick 302
    Yeah, I changed the trans filter and fluid before even trying to drive it. Checked bolts on VB. Fluid and filter looked good. ODO reads 80K miles and I believe it based on overall condition.
  5. Acornridgeman
    Wisconsin
    If I had to guess, I would say torque converter. Shudder is a big clue, as is not engaging at start out and then staying locked up when coming to idle.
    As I said, my best guess. :)
  6. 71gold
    lubegard friction modifier
    that's what I run in all my A/T. my transmission builder puts a bottle in all his transmissions he rebuilds. My thought: if he is standing behind the rebuild and uses this, good enough for me. first time I used this in a used car transmission was A Ford Windstar van. he put in a bottle and no more converter shudder...:thumbs2:
  7. Krazy Comet
    Lubriguard fixes shutter in lockup transmissions that have a clutch inside converter.
    If it helps, the problem isn't/wasn't the converter, C4 has no such device inside the converter.
  8. roblaw
    roblaw Member
    !973 Maverick 302
    When I look up lubegaurd, says not for use with Type F ATF. Which one exactly do you use?
  9. 71gold
    my C-4 didn't use type F. after the rebuild.
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    Vibration and low line pressure(potentially the cause for delay before revving to build pressure) could also indicate a stator and/or pump related issues. Should get a pressure gauge on it asap.
    After adjusting the bands I'd also drop the valvebody and clean it up for inspection of separator plate wear and/or sticky valve movement. Stock replacement parts are cheap enough and you can also replace steel check balls with nylon while you're in there.
  11. baddad457
    My first thoughts exactly
  12. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    If the fluid isn't low and the valve body and filter are correct and tight it's a pump,gasket, seal rings on the pump. Probably need to do a line pressure test. Just to see what it does pour an extra quart in it.
  13. roblaw
    roblaw Member
    !973 Maverick 302
    I overfilled it according to dipstick. It drives pretty good now. So, what does that mean?
  14. greasemonkey
    Sedalia,MO
    Could be wrong dipstick. Could be wrong filter/pan combo.
  15. 71gold
    could mean it had been sitting for a while and just need driving...:huh:
