C4? or C4?
Discussion in 'Technical' started by Racer_X, Jul 15, 2009.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    this is the one thing that has been driving me nuts for a while.
    what is the exact difference between a 250 i6 c4 and a 302 c4? some have told me i need to change it and get a 302 c4 and others say that i can keep the 250 i6 c4 in. Ive even been told that there the same...please help me?!:( im so confused
    i will be putting in a 302 bore .060 over with an RV cam in it
  2. don graham
    My understanding is that the v8 C4 has an extra clutch in it making it a little beefier for the v8. The one from the 250 should work if you don't get on it too hard, too often.:)
  3. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    worse comes to worse, drive it till it dies and either rebuild it to or better then a stock v8 c4 or fine a low mi v8 c4
    I plan to use the 250 c4( supposivly been rebuilt a few thousand miles when i bought the car but hes not sure to what specs o_O)
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I thought the 302 had a larger bell housing
    I can tell you that when I changed over to a 302 from my I6 the only thing I did is get a bigger bellhousing
  5. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Someone will correct me if I'm wrong, but I think the 200 C4 may have had fewer clutches than the V8 trans, but the 250 C4 was the same as the 302 C4.
  6. tim keck
    sharps chapel,Tn
    250 trans will work fine with mild 302s...,.060 over:49:,I hope it don't run hot on ya.
  7. yellow1970mav
    yellow1970mav Member
    cherry hill, nj
    1970 maverick, 2007 Yamaha FZ1,.
    250 c4 trans
    I did the same thing to my mav about 2 years ago. the 250 c4 trans will work and the bell housing will bolt up to the 302. as long as your sure its a 250 and not a 200. If I remember correctly you will need to change the flex plate. the difference is the internal and external ballancing of 250 and 302. :yup:
  8. rthomas771
    As far as I know you're right. The torque converter is looser on a 6 cylinder engine.
  9. Cleaver
    Cleaver Member
    MD
    Chel
    I have a 250 C4 with the 6 converter behind the 302 in my F100. It is a 266 cam, ported 351 headed engine that I run out hard. Always heard the same thing about the clutches but I figured I would throw it in the truck and deal with it later....which was 6 years ago and about 35,000 miles. Still drives the same. The 6 converter definitely pulls less on the brake when sitting at a stop light...so I tend to agree with the higher stall. However, I don't think it is more than a couple of hundred RPM. Sorry for the lack of real technical input...just sharing my experience. I'm sure someone has a story about burning one up in a month.
    Cleaver
  10. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    the 250 and 302 have the same bellhousing, but the 170's and 200's bellhousings are smaller
