c4 or c6
Discussion in 'General Maverick/Comet' started by HOMERMAV, Nov 2, 2008.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    dont know what i should buy to put behind the 1989 5.0 motor c4 or c6
    thanks john
  2. Mavman72
    Go with the C-4,Smaller,lighter,cheaper,just as reliable when built properly.
  3. newtoford
    newtoford Member
    New Castle Delaware
    yea, what he said
  4. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    c6 wont fit...tried it back in the 80's
    robert
  5. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    c4 it is
    im going to a super ford swap meet in columbus ohio thankgiving week end
    so i will look for one then
    thanks for the help.
    john
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    there will likely be a few board members at the swap meet as well. We go every year. I will/was gonna make a post about it in a week or so. I plan on going Saturday. We usually meet for breakfast then go to the swap.
    Maybe you can/would join us.
  7. Craig Selvey
    I will be at the swap meet as well. I can bring you a c4 tranny if you want. Email me directly (see below) if I can help.
  8. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    i thought the c-6 was lighter and all that.
  9. CaptainComet
    C6 is bigger and takes more HP to turn over.
    C4s can be built to take up to 800 HP if done right.
    Very little reason to go to a C6 in a light car anymore.
  10. PaulS
    C4s are built to take 1000 HP and more.
    800 Hp can be done with stock parts in most cases.
  11. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    wow...didnt the c6 come after the c4?
  12. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    C4 = 64 and C6 = 66, so 2 years apart.
    The C4 was designed for low power and/or lightweight vehicles.
    The C6 was for heavy cars, big engines, towing, and trucks.
    The C6 is a very strong tranny just as is. While the C4 is a pretty weak tranny in stock form. Used to be that folks would swap to the C6 to get strength, and just kinda deal with the weight and size.
    Over the years though, the aftermarket has developed parts for the C4 to give it tremendous strength.
    So, before the aftermarket stepped in, the C6 was the answer when you needed a strong tranny. If the C6 didn't soak up so very much horsepower and wasn't so heavy, the C4 probably would never have received attention from the aftermarket.
  13. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    ahhh sweet. Glad to know!
  14. PaulS
    The C4, in stock form was used behind engines as small as 1600 CC 4 cylinders and as large as four barrel 351 Winsor engines in 69 mustangs. In stock condition it can handle 350 Ft. Lbs. of torque.
    The only aftermarket parts that I use are in engines producing 600 HP and up. I do modify the number of clutches, lubrication, cooling and valve body circuits for up to 500 HP but no "after-market" parts are needed until you need an input shaft that will take more than 600 HP. The factory hardened shaft will easily handle 500 Hp.
    There are lots of myths about the C4 but the simple truth is that any C4 from 1971 on that has the 5 clutch plates in the forward clutch and 4 clutches in the direct clutch can be used as is with a shift kit and some minor mods with engines that produce up to 400 - 450 HP and torque - even with the "soft" input shaft.
    The C4 is a great small transmission that can handle the bulk of the small block street performance cars that were built in the 70s and 80s.
  15. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Paul, I saw a c-4 behind a 390 in a stock LTD or Galaxie in the wrecking yard once, stock bell housing and all. And no is was not the FMX it was a c-4, I almost bought it because I had never seen one before and I used to be into FE motors, but I had long since moved on to SB's by this time.
