c4 rear seal
Discussion in 'Transmissions' started by pipman76, Jul 24, 2010.
  1. pipman76
    pipman76 Member
    alabama
    1972 mav
    guys i found that the rubber dust cover thats sticks out around ur driveshaft right behind the rear tranny seal has a crack .Will this leak or does it have anything to do with sealing at all i kinda thought it was more of a dust shield,Oh by the way thi sis a casefill c-4 i just installed but havnet filled with fluid or driven it yet i kinda wanted to see if i need to change this before i go any further
  2. PaulS
    It is just a dust shield (and it doesn't work very well) so that is not part of the sealing surface.
  3. pipman76
    pipman76 Member
    alabama
    1972 mav
    thanx for the help.I just lik to be for sure .when i took the spare yolk out to install the drive shaft some fluid leaked out as they always do and when i had gotten the drive shaft in i notice a fluid drop at the back bottom of the rubber seal and whipped it off and noticed the crack
  4. 71gold
    if i have to buy one that comes w/boot, i cut it off...:yup:
    ...:bouncy:...
  5. PaulS
    Yep, I just never use the boot type seals. I have seen too many that were full of grit, grinding away at the yoke.
