c4 to manual swap
Discussion in 'Transmissions' started by bigdan56, Sep 10, 2012.
  1. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    i have a 77 with a 250 c4 combo and want to change to a 250 with manual 3,4,5 speed not sure which yet my main question at this time is that in one of the many threads i read here some one said that a 77 with power disk brakes never came with a clutch using the stock linkage. is this because of interference with some thing or is it because no one has wanted this combo. also i believe the pedal perch or hanger may be different? does any one have the answers to this because i was going to start this change in about a week or am i wasting my time.
  2. Craig Selvey
    It was not available because it will not fit. You can't get a power disc brake set-up and a clutch pedal to fit together. If you have power disc brakes and want a clutch pedal, you will need to go hydraulic or cable activated clutch.
  3. rthomas771
    Craig - Read what you wrote and explain how the clutch pedal won't fit but the clutch pedal will fit. Are you talking linkage or pedal?
  4. bigdan56
    bigdan56 Member
    Spokane Washington
    thanks for the answers. I was talking the whole linkage as i have not crawled in with the linkage in hand yet. but wanted to ask before drilling holes in the fire wall.
  5. Craig Selvey
    I was talking an entire custom job. The factory clutch pedal will not work with power disc brakes because the brake pedal swings at an odd angle.
  6. injectedmav
    injectedmav Member
    Georgia
    I added the tube for the clutch pedal to pivot on because it's in a different location since I wanted to use a quadrant out of a Fox Mustang so you can modify what you have if you feel comfortable doing so. You will need to fabricate the pedal mount, clutch master cyl mount and obtain a pedal. No stock Maverick manual trans pedal assembly stuff will work due to the odd angle for the brake pedal and booster mounts and no 250 was available with a manual either. There isn't much room on the right side of the pedal bracket due to the angle and booster location so, in my opinion a hydraulic setup would be a better choice if you want to retain power brakes and there is ample room on the left side of the bracket.
  7. John Holden
    John Holden Member
    NJ
    I had power disc brakes in my 75 with a manual trans and stock clutch linkage. It's been a long time but I think all I did was put a little offset bend in the brake rod. Worked perfectly.
  8. bigdan56
    bigdan56 Member
    Spokane Washington
    thanks John that was a word of encouragement i needed. I was starting to dream up all kind of ideas like pillow block bearings and extending clutch pedals or who knows what. i may put this job on the back burner for a little while and spend next weeks vacation freshening the motor so i can keep oil pressure for more then 5 minutes instead.
    and injectedmav i most of misunderstood, you most of meant no manual behind a 250 that had power disk brakes. Because i just put one from a 75 in my garage today complete with motor bell housing tranny and z linkage. But the car didn't have power brakes
  9. John Holden
    John Holden Member
    NJ
    I know you're talking to injectedmav in your second paragraph but I once had a 76 with manual trans floor shift and a 250 with bucket seats. ( I bought the car for parts and put the reclining buckets and pedals in my 75) My 75 came with 250 automatic and power disc brakes. I swapped in a 302 auto and later added the manual trans I mentioned before.
  10. Rockafellow
    Rockafellow Member
    Springfield Missouri
    1974 Maverick 2door
    I have a 74 with a 250 and 3speed on the tree. I would like to use that transmission on my maverick with a 250 and C4/power brakes. I am interested in how it all works, maybe I will tackle my project if its possible! Really enjoyed the 3 on the tree growing up! If I can't, I will adjust to the comfort of the automatic!
    I will stay tuned!
    Chris
  11. bigdan56
    bigdan56 Member
    Spokane Washington
    glad o see the interest from you Chris. i was going to tackle that next week but with a limit on my time and the increase in difficulty i think i am going to concentrate on my motor i can still drive a auto with a refreshed motor but it doesn't go far with a manual tranny and no oil pressure in the motor. i found out about the motor at about the same time i started this thread. doesn't mean i am going to drop that project just move it down the list a little.
  12. mavyforlife
    mavyforlife Member
    yorkton,sk
    1976 ford maverick
    hey im interested in changing over too manual i have a 76 mav, keep me posted on what you need im changing motor to 302 0r 351 c not sure which one yet but if you could help me out as well that would be sweet what kind of tranny which i be looking for thanks everyone
  13. bigdan56
    bigdan56 Member
    Spokane Washington
    thanks for the offer
    :D
    thanks for the offer but i think i have every thing i took from a 74 parts car. i grabbed the pedal hanger the z brackets mounts bell housing trany ect only thing was the disk was wore out but i should be good for parts. still haven't come up with a good solution for the power brakes yet to buy time but get it started may go with manual breaks
    bigger projects like this i have to pull a week or 2 vacation but work hasn't let me do it lately.:cry:
