C4 Transmission Question
Discussion in 'General Maverick/Comet' started by D-Man, Jun 24, 2010.
  1. D-Man
    D-Man Member Supporting Member
    Texas
    75 Comet
    Just got the Comet home from my welding buddy. He was repairing my floor pans and battery tray. :burnout:The car drove great all the way home. I get home, turn off the car and heard a sound like water running under the car. I look and transmission fluid is pouring out from behind the trans. pan. It appears to have happened all at once like something let go. Any ideas as to what happened?:hmmm: Rear seal?
  2. Fastkarz
    Fastkarz Member
    Northern NJ
    1972 Maverick Grabber 347/AOD/4.11
    I have heard of this before. Some kind of anti drain back valve in the torque converter must have went, converter drains once engine is off, and excess fluid comes out tailshaft, vent or speedo cable hole. You might need a trans shop on this one
  3. cheezno6
    cheezno6 Member
    Central ILLINOID
    Pin point the location of where it came out
  4. rthomas771
    I have to agree...sounds like something let go. :yup:
    The modulator valve is behind the transmission pan.
  5. PaulS
    You will have to look to see where the oil is coming from.
    The general term "from behind the trans" can mean a lot of things...
    Pan gasket, modulator fell out, rear seal, rear cooler line, vent leaking..... narrow it down a bit.
  6. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    sounds like he may have pulled the driveshaft off to do the floor? Rear seal probably popped out a bit?
