calming the drone
Discussion in 'General Maverick/Comet' started by wolfheads, Mar 15, 2017.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I'm looking for some input on what resonators would be the best for my exhaust. I have 2 1/2 duel exhaust on my 302 with 14 inch summit racing mufflers. Sound great but at highway speeds the drone gets a little overwhelming. I would like to tone it down a bit but still have a good sound. Any suggestions?
  2. 71gold
    does it exit out the back of the car or the side?
  3. 55crownvic
    55crownvic Member
    colorado springs
    try an "H" pipe
    Static likes this.
  4. wolfheads
    wolfheads MadMav
    Florida
    It exits out the back.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    I have seen quite a few people, myself incuded, chase drone issues with swapped parts only to change the frequency or rpm at which it occurs. THE biggest issue that eludes so many is not the muffler brand or style.. but the isolated suspension of the entire system. If you're buying exhaust suspension components at the local parts store?.. that is likely most of your issue right there. Think soft and resilient OEM hangers.. not cheap rubber straps. 2 by the mufflers and 2 more near each tailpipe.
    Also keep in mind that even 2 inches longer tailpipes exiting further out from underneath the rear of the car will reduce reverberation under the vast open area around the rear end housing.
