cam plate
Discussion in 'Technical' started by rebelgt, Apr 22, 2007.
  1. rebelgt
    rebelgt Member
    Southeast Missouri
    1972 Comet GT
    can the plate that holds the cam in on a 302 be put on wrong? I'm trying to cover all the bases before final assembly. How much horsepower will a 302 bored .030 with flattops and 289 performer with a 600 edelbrock make with stock heads?
  2. 71gold
    fwhp...210 hp...:huh:
    ...:bouncy: ...
  3. 70mav01
    70mav01 Member
    desoto, Mo
    1970 maverick
    Hey Rebel, If you look closely at the cam plate, it has a groove in it. This is for oil to drain down into the timing-chain area. Make sure it is clean before reassembly, as after you assemble it it is a oil drain. the groove should be against the block, draining down. You should be able to get 300 horse, with the right cam, carb, & exhaust system. Good luck.
