can i swap disk breaks from a m2 front and a 9 in rear to my 71 mav?
Discussion in 'Technical' started by JD71, Jan 4, 2010.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    im having my doubts bout doing the m2 swap for now so i would like to know what id have to do to swap the disk brakes from the m2 suspention and the from the 9 inch rear. or if its even possible on a budget. thanks for any help
  2. car-nut
    car-nut Glenn
    conn.
    If I understand correctly.... I would say that the MII and the stock Mav disc brakes are completely different and do not interchange. As for the rear discs, what brake set up are you using??
  3. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    i have the stock 8 inch rear an the disks are on a 9 in but i wouldnt put the back on if i cant use the front
  4. Bryant
    the m2 brakes will not work on the maverick suspension. the 9" brake may transfer over to the 8" if the 9" has small ends and the 8" is 5 lug.
  5. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    actually the disks are all 4 lug
  6. Bryant
    ive never seen a 9" that is 4 lug. i know that that the m2 front end stuff is 4 lug but the caliper will not mount to the maverick spindle. also the rear end from a mustang 2 is a 8" and was only had drum brakes.
  7. baddad457
    The rear discs from the late model Crown Vics will swap to an 8" rear. There's a link to a thread in the Stangnet classic mustang forums on how to do it. There are tons of these cars in the junk yards now.
  8. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    thanks for the input so the rear doesnt seem to be to hard to get done but how bout the front
  9. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    sorry i guess ill add to that last post, as in what cars could i swap the front brakes from an bout how big of a job is it? thanks
