Car wants to stall out when warm, and turning.
Discussion in 'Technical' started by RathEmpire, Aug 2, 2016.
  1. RathEmpire
    RathEmpire Member
    Manitoba, Canada
    2008 Ford focus, 2006 Ford Ranger, 2004 Ford Focus, 1974 Ford Maverick
    Hey everyone. so there's a slight drivability issue with my 74 250i6 Maverick that I want to get sorted out ASAP so I can drive the car more often. It's not a huge issue, but it's one that I want to fix.
    The car fires up and runs really great, no issues until it gets warmed up and i take a turn. when the car isn't up to op. temp this issue doesn't exist. It only happens on moderately tight corners and when I get on the gas mid turn, the car sputters and wants to stall out. If i dont feather the throttle the right way it actually will stall out.
    I have limited knowledge about carbs, but from my basic understanding of them, this sounds like it could potentially be a float level issue? however only doing it when warm kind of throws me off.
    Any help?
  2. bmcdaniel
    Float level would be my guess. Fuel expands some when it gets hot. Also readjust the idle mixture when the engine is warmed up.
  3. RathEmpire
    RathEmpire Member
    Manitoba, Canada
    Sounds good. Will check into the float level and idle mix this weekend. Thanks!
