i was drivng 2 day whn my car died. So i look an whn i get it runing sort of gas starts rapidly leaking gas out of the frnt plate. Its a holley. Wht causes ths and how do i fix it?
Is it leaking past the metering block gaskets???(replace gaskets) Is it leaking out the vent tube on the top of the carb???(Stuck float/bad needle and seat...or debris keeping needle off its seat.Or as Bryant stated...bad float in float bowl (absorbing gas or has a hole in it...if its brass)Good luck!!! Is it leaking past float bowl bolts(get new gaskets for bolts)
