Carb Question
Discussion in 'Technical' started by MarulMav, Oct 19, 2005.
  1. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    Recently replaced the 2-barrel & manifold on my 75 Mav for a new 4-Barrel Holley and Weiend. Started it up today. Needs timing, but here's my question; what would cause the fuel to spew out of the vent holes located above the bowls? I thought these basically came with factory specs with no initial adjustments required. Thanks:confused:
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    :confused: you may have internal carb problems...is the carb new,used....
  3. Jamie Miles
    Alto, GA
    I've had a few
    Float sticking? I accidentally drove my car 3 miles to school and back once with NO needle in the carb. Car ran like crap and was spewing gas out the vent...
    I'll bet it's got something to do with the needle/float.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Float adjustment or float sticking.
    Too high fuel line pressure can do it too.
    Trash stuck in the needle maybe.
    Dave
