Carb rebuild kit/accelerator pump
Discussion in 'Technical' started by Milehighclub, Sep 6, 2011.
  1. Milehighclub
    Milehighclub Member
    near IL/WI border
    1973 Maverick 302V8
    From what i've read it looks like i'm going to need to rebuild my carb. 1973 Stock 302 2 barrel. Do all the kits have everything I need if my accelerator pump is bad and are any kits better than another?
    My car idles fine and runs fine once i'm past the 10mph point. Before that when I take off if I give it too much throttle it cuts out so I either have to take off very slowly which isn't always possible, or brake torque it if I need to take off faster. Engine temp doesn't seem to matter it does it cold or hot.
  2. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    most kits anymore do no contain a new float ,you will probably have to buy that extra
