carbuerator help!
Discussion in 'Technical' started by cometkid510, Jun 16, 2012.
  1. cometkid510
    cometkid510 Member
    michigan
    1973 Mercury Comet GT
    i was wondering what would be the best route to a better running engine... a whole new carbuerator ( and what kind of carb would best fit a 73 mercury comet gt with a 302 with a little power) or to rebuild my holley 4bbl 650 cfm W/vacuum 2ndary?
  2. blugene
    Lota variables besides the carb.. What intake does it have? Mild cam or stock?
  3. cometkid510
    cometkid510 Member
    michigan
    it has the stock cam for the 302 and stock intake
  4. blugene
  5. cometkid510
    cometkid510 Member
    michigan
    when i bought the car...the 2 barrel was gone. The car had a 650 cmf holley on it instead. the guy said that he rebuilt the carb last year....but i don tknow how well he did it
  6. blugene
    Sound like it has an adaptor plate to fit a 4 onto a 2 barrel intake. Just cause it works don't mean it's optimum. I personaly would put a good 2 back on it. Also, having any plate can create problems. I tried this route when I was younger. And it was tried on a 73 GT also :)
  7. 71gold
    get an intake and a 500 CFM carb...:thumbs2:
  8. Bryant
    how do you know its the carb running bad?
    a vacuum leak, bad ignition component or valve problems could cause problems that are blamed on carbs.
  9. 71gold
    it's an old carb. that has been rebuilt over a year ago...:yup:
    removing...adaptor plate to fit a 4 onto a 2 barrel intake and the 650 would be a good place to start...:thumbs2:
  10. cometkid510
    cometkid510 Member
    michigan
    ok thanks!
  11. baddad457
    One question, that has been alluded to, but not asked is: are you running that 650 on a 2 bbl intake with an adapter? Or is it sitting on an actual 4 bbl intake ?
  12. blugene
    See post 2 and 3..:)
  13. baddad457
    He says it's a stock intake, but never actually says it's a 2 bbl. With the experience level he exhibits, it could be either and so far everyone's assuming it's a 2 bbl.
  14. 71gold
    I know I am...:yup:
    "With the experience level he exhibits, it could be either."..do you think he will know...:bouncy:
  15. MSmithPDX
    MSmithPDX Member
    Portland, OR
    You guys are forgetting the golden rule of the internet.
    "Pics or it didn't happen."
    Post some pics of the engine please. Get up close on the base of the carb.
