Carburetor Issue
Discussion in 'Technical' started by Madmax85, Jul 7, 2015.
  1. Madmax85
    Madmax85 Member
    1970 maverick
    Ok guys I need some input from the pros. I have a 70 Mav with the 250, it has a Carter YF on it and that carb is too tall for a hood to close. So I need a different carburetor. I've looked at some "new" rbs carbs online but $300 is a little too rich for me right now, so my question is do any of you know a good source for an RBS or can anyone point me towards some alternate carbs that will fit and allow me to close the hood?
    Thanks in advance for the info.
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    That carb should fit. That's a standard carb for a 250. Did you put a different air cleaner on it?
  3. rthomas771
    250's used the RBS
  4. 71Mavrk
    71Mavrk Member
    Nevada
    I had the same issue when I put a 250 in my '71.
    Look at eBay ad 321800962922
    Micah
  5. Madmax85
    Madmax85 Member
    1970 maverick
    Thanks for the info guys. That ebay listing is probably what im gonna go with.
    The air cleaner isn't the stock cleaner. When I bought the car it had this carb and a cheapo edelbrock foam cleaner on it.
