car's been sitting for 4 months, did I miss anything?
Discussion in 'General Maverick/Comet' started by xpsnake, Apr 17, 2012.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Fluids checked, battery charged, bowls filled on the carb. Tire pressure is good. No leaks on the floor while I was gone. Took the oiled rag out of the carb that I stuffed in there to keep moisture out (no choke).
    It's a dart block will all forged internals and has sat since late November 2011.
  2. Joe Dirt
    id probly pull the coil wire and spin it over a few times to make sure it gets oiled but other then that sounds like you got your bases covered
  3. blugene
    Yea. If your ever around those wheels and tires snap a pic or two.. :D
  4. don graham
    I leave my race car for a couple of months at a time these days. Watch the oil pressure when you start it. Should come right up.:)
  5. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    I agree, with that, but pull the plugs and spray some oil in those cylinders first.Make a mess and be safe..
  6. xpsnake
    xpsnake Bruce
    Took a couple of cranks to get the pressure up, but it came up just fine. Thanks guys.
