Carter RBS heat riser tube
Discussion in 'Technical' started by Mission_Maverik, Feb 21, 2007.
  1. Mission_Maverik
    Mission_Maverik Member
    Maverick
    I have a 73 Maverick with a 250 and a Carter RBS carburetor the heat riser tube is long gone. I cann't even tell where it attached to the exhaust manifold. Does anyone have a picture or diagram of where it should attach. Thanks
  2. PaulS
    There is a boss on the exhaust manifold that has (had) a hole drilled through it (about 1/4") the tube goes into that and up to the choke cavity.from the bottom of the manifold there is another tube that plugs into the clean air side of the bottom of the air cleaner. I am sure that somebody has a photo or diagram to post. Even if I had one I can't get attachments to work here.
