Centre link
Discussion in 'Technical' started by murray, Nov 24, 2021.
  1. murray
    murray Member
    ontario
    74 maverick
    I have a 74 maverick 2 door 250 with power steering the centre link is wearing out needs replacing the problem is there lots of center links for manual steering but none for power steering I'm up here in Ontario but have bee searching across boarder not much luck... now I found a power steering centre link for a 1975 maverick does any know if it will work on my 74 I could sure use some help here .
  2. Krazy Comet
    AFAIK only difference is idler arm, you'll need one for '75-'77.
    I have a '77 center link on my '72 using the late idler.
  3. Craig Selvey
    The center link on a power steering car doesn't "wear out". No wearable parts on it. Solid iron. So what issues are you having?
    CA189HJN, Krazy Comet and dyent like this.
