Changing Dash IP Bulbs
Discussion in 'Technical' started by JPL, Aug 14, 2011.
  1. JPL
    JPL Member
    Ohio
    1975 Ford Maverick "Police Edition"
    77 Maverick, 2 dr, since I got her the Dash IP lights have been dim.....I was drining home the other night from the local Casino:drive: (no, I didn't win:cry:) and hit a little bump in the road and the dash lights (IP) came on a little brighter:dancing:....I thought that was good. Then they went dim....so when I tapped the IP glass (plastic) to see if I can "re-create" the bump action....I lost everything:mad:...drove home in the dark:dance:...any way I know I either have to replace the "dimmer" light (headlight) switch or I may simply have a bad ground somewhere, whatever.....any suggestions before I start on removing the Dash / IP to see inside....appreciate it, later.
