cig. light wiring, blue/red wire under dash?
Discussion in 'Technical' started by xpsnake, May 18, 2005.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I'm wiring a 12v socket for a cell phone charger, since I don't smoke. My '71 did not have the option, I was looking under the dash and found a wire similar to the blue/white one in my '77, is the blue/red wiring for the cig. lighter?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. Jamie Miles
    Alto, GA
    I've had a few
    There is supposed to be a light in the ash tray? :hmmm:
  4. maverick1970
    Missouri
    Never seen one, but it is on the diagram.
  5. bmcdaniel
    I saw that same thing on the wiring diagram for my 70, but I don't have a blue/white wire. I have a blue/red with a 90* rubber boot that would push on the back of the cigarette lighter.
  6. xpsnake
    xpsnake Bruce
    The blue/white was the always on for the cig. lighter, the blue/red was switched with the lights for the accessory lights, thanks guys.
  7. comet 75
    comet 75 comet 75 swap 302
    Quebec
    mercury comet 1975 302
    Yes I got one in my 1975 comet very usefull to don't burn the new carpet (y)
  8. Jamie Miles
    Alto, GA
    I've had a few
    Ohh, well there is no smokeing in my car. :tsk:
    I use my ash tray as a place to keep change. Very handy when you need a quarter going though the drive up at Burger King or somewhere. (y)
  9. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Pretty sure there was an option called "Convenience Light Group" which included engine compartment, trunk and ashtray lights ....
  10. maverick1970
    Missouri
    Anyone know where the connector for the trunk light is on a 70.
  11. dmhines
    Cumming, GA
    I assume it would be an additional harness ran at the factory if it was ordered .. not sure if it was even an option in 1970. My guess would be that it would have connected to the Accessory post on the Fuse Panel ...
  12. maverick1970
    Missouri
    The wiring diagrams show a wire. I am told it is over the left rear fenderwell. I will have to crawl in there and take a look. I have the correct light.
  13. dmhines
    Cumming, GA
    I doubt its there ... just remove your sill plate and see if there is an additoinal wire run to the back besides the normal taillight harness. The factory rear defogger harness was run alongside the taillight harness ... I assume the trunk light wire would be the same ...
  14. Mercurycruizers
    Venetia, PA
    My cigarette lighter has the light from the factory....
  15. Craig Selvey
    Trunk light was a seperate harness.
