Consol and shifter indicator ID ???
Discussion in 'General Maverick/Comet' started by ike72com, Oct 15, 2019.
  1. ike72com
    ike72com Member
    Charleston SC
    Does this console and shifter indicator belong in any 72 comet?
    I can make the small console work but the indicator will have to go.
  2. Krazy Comet
    Console is the Mav/Comet piece, the shifter may be correct but defiantly not the upper quadrant section. These cars use shifter similar, if not same as '69-'73 Mustang.
  3. ike72com
    ike72com Member
    Charleston SC
    Thks KC
    Great to know console belongs in car. I'll stick the shifter bezel on wall as a piece of art.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    The only difference I have seen between Maverick\Comet shifters and 69-73 Mustangs is the shifter arm. The Mustang one on the right is a 67-68 but the arm has the same bend as 69-73. The Maverick/Comet on the left is straight. The straight arm may have been used to avoid contact with a bench seat. You may be able to use that shifter if it will accept a different bezel.
    upload_2019-10-16_5-55-44.jpeg [​IMG]
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    That floor shift assembly is from a 1967-68 Mercury Cougar. Top plate is Cougar only, shift lever and bucket is 1967-68 Cougar or Mustang non-console.
  6. Krazy Comet
    Dayum, you're correct knowed I'd seen it, had same in my '68 GTE.
  7. ike72com
    ike72com Member
    Charleston SC
    I knew off a ford at least. How bout this scoop?
  8. krelboyne
    krelboyne Remember
    Salem, Oregon
    Resembles one off of a Government Motors vehicle. Camaro variation? looks aftermarket.
  9. jasonwthompson
    Carrollton TX
    The only thing that scoop should be off of is, off of that hood.
    BBMS18 and Krazy Comet like this.
  10. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    :rofl2:
