converted to small bumper and front blenkers don't work
Discussion in 'Technical' started by cougar18, Nov 12, 2007.
  1. cougar18
    cougar18 Member
    north ca
    74 maverick/71 comet
    converted to small this weekend but when i went to plug in the front lights i saw that they didn't have a ground strap like the 74 did when you turn the blinker on it just lights up no blink. is the casing grounded to the bumper or do i have to convert something else?:hmmm:
    thanks
  2. Mavaholic
    Did you swap in the under bumper lights or are you still using the grill lights?
  3. cougar18
    cougar18 Member
    north ca
    under bumper light. using driving light from the grabber in the grill so i can't put in that spot
  4. newtoford
    newtoford Member
    New Castle Delaware
    if they come on it wouldnt be a ground issue right? sounds like it would be the flasher in the fuse box if they just light up but dont flash
  5. cougar18
    cougar18 Member
    north ca
    sorry i miss wrote that they don't come on at all but when i plug the old one back in they turn on but won't blink unless i ground with the wire. i printed out the wiring diagram for the 72 and the74 and they both show a wire coming out to the ground but the 72 dosen't have that wire. i know somebody on here has converted and has run into this prob. i need help (wifes car)
  6. cougar18
    cougar18 Member
    north ca
    come on i need some help my wife is starting to look at me in a bad way she cant drove her car
  7. Rando76
    Rando76 Member
    Claremore, OK
    If I remember right, those lights ground to the body. Clean up the mounts if they're rusty - make sure they're getting good contact. The grill lights have a ground wire the mounts to the core support.
  8. cougar18
    cougar18 Member
    north ca
    thanks that what i tought but i wanted to make shure thanks again
  9. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    blenker fluid is probably low!
  10. Jamie Miles
    Alto, GA
    I've had a few
    Randy is correct, they ground through the house of the lights themselves. That means three possible points for a bad ground... between the bumper brackets and front frame, between the bumper and the bumper brackets, or between the light housings and the bumper. I'd also be sure to check there is no corrosion or anything in the light sockets.
