Converting column shifter to floor shifter
Discussion in 'Parts Interchange' started by 6.2man, Jul 13, 2016.
  1. 6.2man
    6.2man Member
    Onalalaska wa
    71 maverick grabber
    I had a column shifter given to me . I needed a floor shifter column . I didn't need it just wanted it to look factory . Then I knew a guy who was into mustangs . He gave me a partial column and said any parts from it would convert the shift column . Is this true ? Thanks
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Should be good if both columns have a key on them. I used parts from an 89 F150 to convert mine.
  3. Doug
    Doug Member
    washington state
    71 maverick grabber
    Yep both have keys
  4. RMiller
    Kennewick, WA
    Should be good to go if all the pieces you need are there.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I used parts from a 71 - 73 Mustang column, perfect fit.
