Cool upgrade
Discussion in 'Technical' started by Fordmaster169, Oct 1, 2006.
  1. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    I was getting a 1986 LTD/Crown Vic ready to go to the junck man today and I got a thought. What parts off this car will be good to retro to a Mav? I had a brain storm and came up with a very easy and cheep upgrade for our cars. The car had a electric trunk release and I was wondering if I could adapt it to a Mav. Well the answer is yes. I took the trunk latch out of the trunk lid on the LTD and took it over to the 75 parts car I am almost done stripping for the parts. I took the old latch out and tried to fit the 86 electric latch in. The latch mount needs a little mod but not much. I got it to fit and low and behold the bolt holes are the same (but it only uses 2 of the bolt holes not all 3) and it bolted right in. I closed the trunk and it latched. I then adjusted the latch so the trunk would close tight and WHOOOOO HOOOO!!!!!!!!! You can use the stock lock and everything works fine. All you have to do then is run the wires from the front to the latch and there ya go, a electric trunk release for very low dollars. You could even use the stock button if you wanted to.
    Just thought I would pass this along. I know I have been thinking of how to do this for some time now.
    Don
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Neat deal!
  3. Dave B
    Pictures..pictures..we need pictures!!! Cool idea!! and great info!!
  4. stmanser
    Davenport, Iowa
    awesome... that sounds like an easy mod...
    pics please
    and how about a step by step?
  5. maverick75
    Cool, thanks for the tip(y)
  6. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    thanks for the tip
  7. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    Try a Thunderbird one.
    The electric latches from 83 thru 88 Thunderbirds are a direct bolt on. That was the first cool mod I put on my car. I cut the switch from the glove box out also and mounted it under my dash, by the e-brake.
  8. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Great info.....I have a '86 Tbird ..... I might try that. Thanks
  9. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    Thanks for the info!!!!
    jerryfow2
  10. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Neat trick, thanks(y) .
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
