cooling
Discussion in 'Technical' started by mavmo, Jul 8, 2013.
  1. mavmo
    mavmo Member
    Vancouver wa.
    71 maverick
    Iam running a 408w in my 71 , thw problem I'm having is cooling driving down the freeway.It won't cool due to radiator capacity, I know some of you guys run big power what are you running for a radiator? Thank s.
  2. yellow75
    Tillamook Oregon
    Hey Rick, are you using an electric fan, how about a radiator shroud, I am not running big horsepower but mine stays cool even at the strip. I am using a 3 core Aluminum Champion Cooling Radiator as do quite a few people on here but most people dont have issues on the freeway.
    Mike
  3. 71gold
    what RPMs are you turning?
  4. lm14
    lm14 Member
    Iowa
    If it won't cool at highway speed, you have an airflow problem. The air isn't going thru the radiator. Either you have bent fins or a plugged radiator.
    SPark
  5. mavgrab302
    Also make sure your lower rad hose isn't collapsing, I had that problem right after I got the car driveable... When at idle looking for a issue it was fine, at higher rpm's the lower hose would collapse...
  6. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Check your timing as well. I had a timing issue that would cause the car to get hot at highway speeds.
  7. Krazy Comet
    A lean A/F ratio at cruse will also cause a rise in temp in a marginal system... One of my freinds had had that issue with a 350 in a '65 Chevy II, once he re-jetted the carb and got it in the mid 14:1 range it's been fine(was in high 15s)...
  8. Bryant
    also are you running a thermostat?
