core plugs install
Discussion in 'General Maverick/Comet' started by BIG T, Mar 23, 2014.
  1. BIG T
    BIG T Member
    Ventura Ca.
    Hello, can you tell me what is the best sealant to use when installing core (freeze plugs).? Thanks again for helping with my blow by and pinging problem. I found broken rings on all but #1 piston. When I pilled the starter a nut fell out That was the pinging problem (30 years on the flight line):drive:
    Thanks
    Tony
  2. Dave B
    I use gasket shellac.
  3. rthomas771
    X2 on the shellac. I wouldn't use silicone
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    I usually just clean up the plug bores real well and then use red Loctite. The old style shellac works well enough to.
  5. Acornridgeman
    Wisconsin
    Permatex Form a Gasket #1
    What I was trained with in tech school back in the '70's
    Old habits are hard to break ......... ;)
  6. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Permatex "The Right Stuff," black.
    My $0.02,
    Eric
  7. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Permatex #3 ,brush on is what I used all day long ,professionally.(y) :tiphat:
