Cover for the space between the back seat and trunk
Discussion in 'Cosmetic' started by bobdobbs, Apr 27, 2012.
  1. bobdobbs
    bobdobbs Member
    Oregon
    76 Maverick
    I'm rebuilding my interior and I've put in the peel & stick for the floorboard, but I couldn't find any techniques people have used for the space behind the back seat.
    I still had the original tar paper, so I glued automotive carpet to both sides with spray adhesive and trimmed it to fit. I thought I'd share because I searched here a while back and couldn't find any notes from people who'd done it.
    Cheers
  2. bobdobbs
    bobdobbs Member
    Oregon
    76 Maverick
    Thanks! Mine was pretty bad too. In some cases, I had to guess where the slots would be where it hung on the hooks. I need to get a pic of it from the trunk side. It looks nice.
    Another trick I forgot to mention: glue carpet on one side, then cut all the slots and the outer shape BEFORE you put the other side on.
  3. cometkurt!
    cometkurt! Member
    south paris maine
    thats cool.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Hell of an idea! I'd have to go from scratch though, mine's long gone.
  5. maverick75
    So the old one is used as pattern/base, that is a very cool trick!
    I just ended up using one from a Probe, it fit nicely and it's plastic/foam.
  6. Craig Selvey
    I like what you did.
    Reproductions are available for the original style of trunk seperator as well.
  7. rthomas771
    And what is the difference between the two that AK sells other than the $5? I take it that the LDO is thicker materal?? :huh:
  8. Craig Selvey
    I guess I haven't looked to see that Auto Krafters sells two different versions.
  9. bobdobbs
    bobdobbs Member
    Oregon
    76 Maverick
    Looks like one is specific to the 72-77 Lux Decor Option. I think if you didn't have the tar paper template, you could still get away with two pieces of carpet glued together. I would just cut the slots for where it hangs, cut out the places where the seat bolts on and cut relief slits for the sides and bottom.
    http://www.autokrafters.com/v4/go.g...d=687&yearId=1973&&ACESSearch=1&product=31981
    [​IMG] TRUNK DIVIDER BOARD 70-77 MAVERICK 71-77 COMET Part Number: TDB70MAV
    Price: $19.95 USD
    [​IMG] TRUNK DIVIDER BOARD 72-77 MV/CM W/LUX DECOR OPT Part Number: TDB72MAV
    Price: $29.95 USD
  10. Craig Selvey
    O.K.....now I remember. The LDO has a thick carpet like "jute" insualtion to the back side. The other is just tar paper.
  11. youngster
    youngster New Member
    massachusetts
    1970 maverick
    i just removed mine glued some foam for padding cause my tar paper literately crumbled
