Coverting To Floor Shift 69.5
Discussion in 'Technical' started by dschrodt, Aug 30, 2008.
  1. dschrodt
    dschrodt Member
    Ellijay, Georgia
    1969.5 Maverick
    We're converting to a floor shift auto, as we could not get the column shift linkage to work with our headers after the 302 swap. We've got the B & M shifter, and it has the switches for neutral safety and backup lights, but we're not sure which wires go to which? There are 4 wires on the harness going to the column mounted neutral safety switch. Before we start cutting wires, can anyone give a heads up on which wires go to which switch?
    Also, it looks like the front mounting bolt for the shifter is supposed to have a nut on the underside which is over the transmission, and appears impossible to get to with the tran in the car. Any suggestions?
  2. dschrodt
    dschrodt Member
    Ellijay, Georgia
    1969.5 Maverick
    Never Mind
    Got it. Never mind.....(y)
