Cowl test question
Discussion in 'General Maverick/Comet' started by vern, Apr 7, 2007.
  1. vern
    vern Member
    New Jersey
    When I pour the water to check the cowl do I pour it on the windshield in the corners or directly down the vent in the middle of the cowl????
    I am doing this tomorrow and this has me concerned as it could be a bigger fix than I want to get into....I am not that good a welder..
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    pour it right down the middle of the cowl. But I use a different method, a strong flashlight shining down the cowl vent in the dark and someone laying under the dash when you can see just exactly where it leaks and how bad it all really is.
    Dan
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If the cowl leaks you can always fill the vents in.
  4. stmanser
    Davenport, Iowa
    even after you cover the cowl.. you will need to check the weep holes just under the rubber seal of the windshield, and the drain holes inside the fenders for areas for water to get it.. i had to completely seal off all those areas on my mav... and it still leaks
  5. 71gold
    pour directly in the vents...windshield leak is another story :yup:
    ...frank...:bouncy:
