how do I replace the bushings on my 76 2 door to make the creaking go away or is that even the problem any help would be awesome
Did you grease the bushings when you put them in? Also, could be the spring saddles. Those things will drive you nuts.
Creaking could be the notorius upper control arm bushings that can't be greased unless you cut a hole in the shock tower (uggh) or buy a 90 degree grease fitting kit. Check at AutoKrafters, that's where I got mine. $20 "gamble" could save a lot of time under the car. http://www.autokrafters.com/v4/go.g...=&modelId=&yearId=&&ACESSearch=&product=30811 bottom of page.
I would guess that it's the upper control arm bushings at least 80% of the time. Actually it has been 100% of the time for all the ones I have fixed. I've done it each way before too, put holes in the shock towers, used the 90 degree fitting, and just replaced them before. Fixed it regardless.
