custom gas tank?
Discussion in 'Technical' started by FoMoDave, Apr 24, 2005.
  1. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    I was thinking about replacing my gas tank in my 73 and since no makes replacement tanks , why could'nt I just make my own from either steel or aluminum.That way I could make it fit the car the way I want it to fit. I would make it so I could use stock type sender from any number of fords that would be easy to replace. Anyone have any thoughts as to why this would not work or any input on this? If it did work out would any one want one for their car? It would not look like stock tank ,more like fuel cell,but would bolt in using stock mounting location. To me it seems like it would be a simple thing to make but maybe there is more to it??
  2. Jamie Miles
    Alto, GA
    I've had a few
    Yep, my dad made one out of aluminum back in the early 90's for his Comet. Worked great.
    Not sure if I have any pics, but I'll look.
  3. FoMoDave
    Cumming Ga.
    Pics would be great if you can find one. Any info on how to go about it would help too.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Aluminum is easier to bend, harder to weld. Steel is harder to bend, easier to weld. How good are your welding and fab skills? That is the best way to decide what you feel most comfortable with if you do it your self.
  5. Thack
    Thack vision advicator
    Moreno Valley Ca
    I made Tammy's out of 6061-t6 aluminum. I used a stock sending unit mounted on the top of the tank and made a seperate pick up tube. I put a drain in centered the tank and put in bevels for exhaust clearence. That tank holds 19 gal, of course I did all that work only to find out that dennis/mavohalic used a mustang tank and basiclly got the same result.
  6. Jamie Miles
    Alto, GA
    I've had a few
    Well, I can't find any pictures of it. If I were doing it, I would go the Mustang tank route.
