cuts out
Discussion in 'Technical' started by zach71maverick, Jun 10, 2009.
  1. zach71maverick
    zach71maverick Member
    Buford, GA
    I just replaced my carb and had it tuned. Now when i drive it will go and then it loses power then it comes back. It doesn't turn completly off it just does it for a second. Then it comes back and then it will do it again. WHat would be the cause of this?
  2. maverick75
    Sounds like its starving for fuel,check the lines for kinks, also inspect the fuel filters.
  3. PaulS
    Crimped lines, clogged filter (in the tank or at the carb), junk in the tank, junk in the carb partially blocking the jet(s) and fuel separation from moisture.
    All can cause the same symptoms.
  4. pesty351
    pesty351 Member
    Tyndall AFB
    76' Maverick
    What fuel pump/system are you using?
  5. zach71maverick
    Buford, GA
    i dont know fuel pump/system is on it, it was there when i bought it. I took it out this morning and it did it once and then ran like a dream after that so im a little confused.
  6. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    I hope not for your sake but My Dad had a car that used to do that, it was from his favorite son (me :rofl2:) dropped rocks in the gas tank. DOH!!
  7. Earl Branham
    Lugoff, SC
    Check the needle and seat in the carb. If it closes down or sticks, the carb will run out of gas. Also, check the fuel pump for the correct fuel pressure (6-8psi). Good luck!
  8. brainsboy
    brainsboy Member
    Tampa
    I rebuilt my carb too and had the same problem. It turned out that the needle was sticking open and gas was running in the throttles flooding the motor. It wouldnt kill it and reving it up a few times sometimes would help unstick the needle and it would run fine again until it sat for a few days. My fix was to adjust the float level down 1/16 of an inch. Interesting thing was that originally I set the float level to what the rebuild kit said too.
